Canon 1080/25p and Panasonic 1080/50p in one timeline?
COW Forums : Test Posting Code Here
VIEW ALL   •   PRINT
Florian Walter
on Nov 12, 2012 at 3:52:47 pm
Hi out there.
I have a problem as I have to film with two different cameras tomorrow. And afterwards I edit the images in one single timeline. I have no other option than these two cameras:
One is the Canon 7D
The other one the Panasonic HDC-SD909
Canon 7D only records 1080/25p
The Panasonic HDC-SD909 records always interlaced, BUT: one can additionally record 1080 at 50fps. There is NO option of recording 1080/25p.
I will now film with Canon at 1080/25p and Panasonic with 1080/50p.
My possible editing suites are Final Cut 7, Final Cut X and Adobe Premiere (at the university).
My Plan:
- to film both cameras progressive (25p and 50p) and to export the Canon7D material to Prores 1080/50p. Then I can simply open a 1080/50p timeline in Final Cut.
My questions:
- It makes sense, as I only have to double the images ... I will not loose anything, right? Is it the best workflow?
- Or better export to Prores at 1080/25p?
- Or should I record interlaced? But the 7D does not record interlaced ... I guess that makes no sense at all, even if I could re-compress it to 1080i, as I will only loose quality, right?
Thanks for helping me out! Thats kind of you! Best, Florian.
Visual and Media Anthropologist
Final Cut Editor
Florian Walter
Re: Canon 1080/25p and Panasonic 1080/50p in one timeline?
on Nov 12, 2012 at 6:37:21 pm
Anyone?
Final Cut Editor
Florian Walter
on Nov 16, 2012 at 8:48:50 am
Okay, problems solved. I have recorded in 1080p50 with th Panasonic and with 1080p25 with the Canon7D.
Then I converted it to a ProRes Format with 1080p25 and both cameras look very nice on a Final Cut timeline. The look is quite similar, even the colours match more or less.
Final Cut Editor
VIEW ALL   •   PRINT
