bridge, retrieving blacks in RAW
COW Forums : Blackmagic Cameras
Ali Quintana
on Nov 5, 2013 at 2:34:33 am
I love the exposure slider in Bridge, you can really retrieve so much highlights in RAW files by just sliding to left and also use recover.
Even in really over exposed footage.
Blacks though doesnt have a slider like this. I filmed some
footage where blacks are clipping? Anny way to retrieve this? I tried curves, does do something upto a certain extend but nothing compared
to the way highlights are retrieved.
Matthew Sonnenfeld
Re: bridge, retrieving blacks in RAW
on Nov 6, 2013 at 9:29:35 pm
Try lifting your gain/exposure.
Co-President at fourB Productions, Inc.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 16GB RAM
2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
Ali Quintana
on Nov 7, 2013 at 12:29:59 am
I found out I mostly need to bring the exposure down just a little for the highlights not to peak.... So bringing it up is not really an option.
Is there any other RAW editing program that does allow to retrieve peaking blacks?
Matthew Sonnenfeld
on Nov 7, 2013 at 3:09:32 pm
The BMCC was really built to be graded in DaVinci Resolve. I know it's intimidating but that will ultimately give you the most control over the image and raw processing.
Ali Quintana
bridge CS6, retrieving blacks in RAW POSSIBLE
on Nov 11, 2013 at 4:16:11 pm
unfortunately DAVINCE DOESNT OPEN ON MY POWERCOMP yet, still have to look into that. But now I have an urgent TV spot I need to edit so have to
use bridge for now.
But I solved my problem. As CS 5 bridge (which I was using) doesnt allow blacks to be retrieved I tried CS6 and BAMMMMM yep, blacks can also be retrieved.
Any tips on workflow?
I normally make sure my whites are not clipping and the blacks are not clipping. This as I noticed that once they clip it can not be retrieved in AE. So basically thats all I do in bridge... and a bit clarity as well.
In AE I use Synthetic aperture for further work and the collorista 2.
Anny tips for the Bridge cs6 stage when importing into AE will be very welcome....
