4x4 mattebox for BMCC
COW Forums : Blackmagic Cameras
Alexander Nilsen
on Jun 18, 2013 at 8:58:42 pm
Is it possible to have a 4x4 mattebox on the Blackmagic Cinema Camera 2.5K EF mount? What could the effects be? I'm checking out the Tilta III DSLR Shoulder Rig which is a little cheaper than the Blackmagic solution they have.
Matthew Sonnenfeld
Re: 4x4 mattebox for BMCC
on Jun 19, 2013 at 8:54:12 pm
That's all about your lens. Chances are you will be fine with a 4x4 as you will probably not be wide enough to vignette on the 2.5k version. This is typically the problem with a 4x4 system. Wide lenses may see the edge of your filter. But unless you are using some very wide glass, due to the crop factor you will probably be alright most of the time. As per effects, you have the option of anything that comes in a 4x4 which is just about anything. Tilta stuff is very good too.
Co-President at fourB Productions, Inc.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 16GB RAM
AJA IoXT
Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
The College of William and Mary
Alexander Nilsen
on Jun 19, 2013 at 11:34:18 pm
Ah ok, because of now I'm using a MIR-20 wideangle as my widest lens. It's about 93mm wide. Thought I read in the description of the Tilta rig that lenses below 110mm should be fine. What do you think?
Canon XA10
Merlin Steadicam
Tilta 3 DSLR rig
iMac intel i5
Matthew Sonnenfeld
on Jun 19, 2013 at 11:39:57 pm
What you've read is really talking about the diameter of the lens, not the focal length. What is the focal length of your lens? But yes, that diameter will fit in the mattebox. The questions of whether or not it will vignette is dependent on the focal length.
AJA IoXT
Alexander Nilsen
on Jun 19, 2013 at 11:46:03 pm
The focal length is 20mm as it is the widest lens I have at the moment. How wide could I go before I get the vignetting effect?
Canon XA10
Merlin Steadicam
Tilta 3 DSLR rig
iMac intel i5
Matthew Sonnenfeld
on Jun 25, 2013 at 3:28:30 pm
Given the crop I'm not exactly sure now wide you could go as I have not tested it myself, but I'm reasonably confident that you won't run into any trouble with that lens.
AJA IoXT
