BMCC-EF lens compatibility list
COW Forums : Blackmagic Cameras
Peter J. DeCrescenzo
on Jan 29, 2013 at 5:01:37 pm
BMCC EF lens compatibility:
An EF lens BMCC compatibility list is being maintained on Blackmagic Design's user forum.
http://forum.blackmagicdesign.com/viewtopic.php?f=2&t=4159
The list is based on informal reports from end users working with the current BMCC firmware v1.1. It's possible the results may change with subsequent BMCC firmware releases (a v1.2 beta firmware has been announced but is not available to the public yet), so YMMV.
There have been numerous reports of an infinity focus issue with the Tokina 11-16mm f2.8 zoom lens on the BMCC-EF.
http://forum.blackmagicdesign.com/viewtopic.php?f=2&t=3807
A few users report that their copy of the EF-mount Tokina 11-166mm lens works OK, but most do not. A few users of the Nikon mount version report good results using a Novoflex Nikon-to-EF or other lens mount adapters, but most do not.
An alternative ultra-wide-angle rectilinear zoom lens for use with the BMCC-EF might be the Canon 10-22mm or Sigma 8-16mm. Of course, these aren't as fast as the Tokina 11-16mm, but are reported to work (and have been used to shoot many of the BMCC videos on Vimeo.com) Note: YMMV & buyer beware.
Since the BMCC-MFT isn't shipping yet, I'll leave it to others to discuss lenses for use on that camera. I'm waiting for a BMCC-EF myself.
I strongly recommend not buying a lens before you have a BMCC in-hand, and only buy lenses from a reputable dealer with a 100% refund policy. Another approach is to rent a lens from a company such as lensrentals.com so you can test it on your camera before deciding which lens to buy.
The BMCC-EF & BMCC-MFT cameras feature focus peaking and magnify focussing aids on the LCD, but they don't support lens AF. So whatever lens is used must include a manual focus feature. In the case of the BMCC-MFT, lenses such as Panasonic Lumix MFT require power to focus & set aperture, and so can't be used on the BMCC-MFT's passive lens mount.
Cheers.
http://www.peterdv.com
Blog: http://herefortheweather.wordpress.com
Re: BMCC-EF lens compatibility list
on Jan 30, 2013 at 4:48:06 pm
UPDATE: There may be a solution for the Tokina 11-16mm f2.8 infinity focus issue. Stay tuned for details ...
http://forum.blackmagicdesign.com/viewtopic.php?p=28464&sid=0d4c10f2addce03...
on Jan 31, 2013 at 5:45:27 am
On an indirectly-related note: New BMCC firmware v1.2 released today.
See:
http://forums.creativecow.net/readpost/367/335
on Jan 31, 2013 at 11:39:39 pm
FYI: Christian Schmeer describes in a blog post a possible DIY fix for the Tokina 11-16mm f2.8 lens infinity focus issue. YMMV!
http://blog.christianschmeer.com/tokina-11-16mm-f2-8-focus-adjustment/
on Feb 2, 2013 at 3:08:47 pm
Update: Apparently, initial reports of the Canon EFS 10-22mm zoom being compatible with the BMCC-EF were incorrect.
An alternative ultra-wide-angle rectilinear zoom lens for use with the BMCC-EF is the Sigma 8-16mm. It’s not as fast as the Tokina 11-16mm, but it’s 20% wider at the wide end, and fully compatible. For example, the Sigma 8-16 was used for all the extreme wide shots in these two BMCC-EF videos:
Ali Quintana
on Oct 9, 2013 at 11:03:03 pm
The canon EF lenses have a red dot where to connect to the camera, some have a white dot... they seem to work on the BMCC and say EFs instead of EF.
Do you have any insight on this?
