ultrascope software via thunderbolt
COW Forums : Blackmagic Cameras
Ramil Pasibe
on Jan 17, 2013 at 2:57:09 am
Hi Guys,
our blackmagic cinema camera just arrived and I managed to test the ultrascope software on a 13 inch macbook pro. The problem is that I cannot display all 6 displays for monitoring because of the screen resolution.
Is there any other way aside from getting a 5 inch macbook pro to fully display all of them?
thanks a lot.
Juan Salvo
Re: ultrascope software via thunderbolt
on Jan 17, 2013 at 5:30:56 pm
iMac will also do it.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Ramil Pasibe
on Jan 18, 2013 at 2:44:06 am
Thanks Juan.
Yeah it will do but bringing an imac on set is quite cumbersome. I guess there's no choice but to go 15 inch then. Thanks a lot.
Juan Salvo
on Jan 18, 2013 at 5:12:58 am
Not just 15, but retina 15. Need 1920x1080+ for 6 up display,
Chris Pearse
on Jan 18, 2013 at 8:08:44 am
I tried UltraScope on my MacBook Pro Retina 13". Whilst UltraScope will run, the performance is not great. However I see someone has mentioned recently on another forum that a program like Quickres might allow you to run all six scopes at once.
The MacBook Pro Retina only allows up to the equivalent of 1680x1050, whereas the six-up view needs at least 1920x1080. Quickres allows you to use resolutions all the way up to the retina display's native resolution. I can't verify this myself right now, and I expect performance will be even worse, but maybe if you want to try it on this system, it seems like the only way to go.
Chris Pearse
Blackmagic Design
