Newbie question please.
COW Forums : Blackmagic Cameras
Ofer Levy
on Sep 29, 2015 at 1:21:25 pm
Hi all,
I know I am a bit late to the party but I just bought a second hand Production Camera 4K. All I can say is WOW! Image quality is just mind blowing.
Managed to use it a bit in the last few days and I can't get the "Frame Guides" to show.
In the manual I see a long list of "Frame Guides" but on my menu I don't see any.
I have updated to the recent firmware.
Please can anyone clarify?
Ofer
http://www.oferlevyphotography.com
erik cantu
Re: Newbie question please.
on Sep 29, 2015 at 2:57:12 pm
In the display menu setting (where you adjust zebra bars and LCD brightness), select which frame guide you would like to use, and then in the main menu area (where you can format disk and enter metadata) make sure Frame Guides is enabled-lit up.
Simply enabling frame guides won't do anything as the default frame guide to show is nothing. You must select the formatting deeper in the menu. This way you can have the guide you like, but also switch it on and off quickly.
Erik Cantu
Video Producer
RadioU TV & Animal Basement
14 years experience as a fulltime broadcast shooter, editor & broadcast designer.
Ofer Levy
on Sep 29, 2015 at 10:16:52 pm
Thanks Eric,
The thing is I don't have any 'Frame Guides' options in the settings menu. When I press the 'farme Guides'and it lits up - nothing is showing on the LCD.
Cheers,
Ofer
erik cantu
on Sep 30, 2015 at 12:45:35 am
I posted this video on myself enabling the frame guides on my BMCC.
Make sure you are running current firmware, or at least v2.1 and up. Firmware must be downloaded from blackmagic with each new build.
Erik Cantu
Video Producer
Ofer Levy
on Sep 30, 2015 at 10:39:36 am
Thanks Eric for your help.
I realise I need to update the firmware as I can't see the Frame Guides as my camera still running an older firmware.
Cheers,
Ofer
john mahoney
on Oct 5, 2015 at 6:44:01 pm
I am in the same boat, Just got used BMC 4K. Came here looking for frame guide help. First post was about the issue. Question is, how can you tell which firmware you are on?
Kalle Kannisto
on Oct 7, 2015 at 4:59:09 pm
See:
http://forum.blackmagicdesign.com/viewtopic.php?f=2&t=7896
The gist of it is that you can run the Blackmagic Cinema Camera Utility to check whether the firmware is up to date, but it doesn't tell you what the installed version is.
john mahoney
on Oct 7, 2015 at 5:08:01 pm
I downloaded and updated, the frame guide option is now working. I did not get the option to delete the old firmware.
