will BMCC overheating
COW Forums : Blackmagic Cameras
Ali Quintana
on Jan 22, 2015 at 3:06:48 am
Need to film in very hot climate (34 Celsius)and in the sun this weekend.
Have the tilta ikan rig which has holes for the Camera Fan,
Should I still be concerned about overheating.
Will be filming RAW.
I know the cam gets very hot quickly which is why I am asking.
erik cantu
Re: will BMCC overheating
on Jan 22, 2015 at 6:04:26 pm
If you operated the camera in any shade, I am not sure if you would have problems, especially recording RAW; but if the camera was in direct sunlight I would expect heat problems. I would do what you can to keep the camera body out of direct sun and keep air moving around it.
Erik Cantu
Video Producer
RadioU TV & Animal Basement
14 years experience as a fulltime broadcast shooter, editor & broadcast designer.
ToNY D. [cbmg]
on Jan 25, 2015 at 7:08:19 am
I would keep out of direct sunlight because the metal may conduct heat faster than a DLSR.. But the fan on the BMCC seems very powerful.
