A couple of queries
COW Forums : Blackmagic Cameras
Dave Edwards
A couple of queries
on Jul 28, 2014 at 4:33:42 pm
It seems hard to get sharp footage from the BMPCC: is this likely to be because a $250 lens will simply not be as sharp as a $600 lens?
Surely a lens intended for use with a 12 megapixel still camera ought to do pretty well with just 1920 x 1080?
The camera does produce sharp footage on occasion but not routinely and low light seems to produce noise all too easily.
Paul Del Vecchio
Re: A couple of queries
on Jul 29, 2014 at 2:06:25 am
I've noticed that low light, underexposed footage produces softer images. It's like that on every camera I've used. It also depends on your contrast ratio on set, and also yes, the type of lens. It's different for every lens. Which lens is currently giving you issues?
As an example, Rokinon lenses are pretty good when it comes to resolving detail, but open any of them up all the way, especially the 24mm T1.5 and it becomes a soft mess with horrible contrast. The whites bleed all over the place, creating an even softer look. I wouldn't use the Rokinons at anything below T2 and even then, I may add a tiny bit of sharpening.
Most lenses are sharpest between 4-5.6, but some can hold contrast and detail great at 2.0. It depends on the lens.
Paul Del Vecchio - Director
http://www.triple-e-productions.net
http://www.pauldv.net
Dave Edwards
on Jul 29, 2014 at 9:14:21 am
Thanks for your reply Paul: I've been experimenting with MFT Lumix lenses: a 14mm prime, 14 - 42 and 40 - 150.
