BMCC & Paralinx Crossbow
COW Forums : Blackmagic Cameras
Nigel Thompson
on May 9, 2014 at 6:14:34 pm
Has anyone used or have been using A black Magic Cinema Camera with A paralinx cross bow ?
How does it operate and does it operate at all? can i run an HDMI cable directly from the crossbow to a monitor ?
High End, Production & Post Production
in the Caribbean
http://www.bistt.com
Richard Martz
Re: BMCC & Paralinx Crossbow
on May 9, 2014 at 6:56:40 pm
The crossbow converts the SDI signal to an HDMI signal that is then fed to the Paralinx transmitter. Theoritically you could just put the HDMI signal into monitor. But, just a warning, the Crossbow does not support 23.98 frame rate. So if you want to monitor anything then it will have to be 59.94.
When we need that capability we re using a Blackmagic SDI to HDMI mini converter. A bit more expensive but it will convert virtualy any frame rate we need.
Sincerely,
Richard Martz
MagicMartz Media, Inc.
BrikPower Batteries
Atlanta, GA
FCP 7
FCP X
Blackmagic Cinema Camera
ADOBE CREATIVE SUITE CC
Premiere Pro
DaVinci Resolve 9.0
MAC 8 core w 32GB memory
After Effects
PhotoShop
Illustrator
Sony HD Cameras
24' Camera Crane with Motorhead
8' jib arm
20K watts of lighting
Multitrack audio
Teleprompters
Grip Truck/trailer
Location video monitoring
Door and hood mounts
Lots of other Fun Stuff!
Nigel Thompson
on May 9, 2014 at 7:10:24 pm
thats interesting i was told the BMD mini converters dont work on the BMCC. Oh well
in the Caribbean
