BMCC - Dropped Frames in RAW
COW Forums : Blackmagic Cameras
Zachary Rutledge
on Feb 10, 2014 at 1:00:28 am
I'm using the recommended SSD's but still getting dropped frames when recording in RAW. Is this a firmware issue, camera issue or can multiple formats and uses actually start to damage the SSD?
John Fishback
Re: BMCC - Dropped Frames in RAW
on Feb 10, 2014 at 6:08:04 pm
The first thing I'd do is make sure the SSD contacts are clean. Also, get smoe compressed air and blow out the camera's contacts. I haven't heard this is a problem, nut I know P2 cards had problems when the contacts were dirty. The SSD only has a finite life, but that shouldn't be happening if it's relatively new.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
