ALWAYS FORMAT - Never simply trash files
COW Forums : Blackmagic Cameras
Richard Martz
on Jan 22, 2014 at 7:07:46 pm
One additional tidbit of information that might be critical…After recording on your drive you will probably want to transfer them to another storage medium. I recently made the mistake of simply trashing the files on the SSD after they were transferred.
This colossal mistake resulted in not being able to record on the full capacity of the drive for some reason. It was like the files that I trashed were still there. I discovered this after attempting to duplicate the problem. Formatting the drive eliminated the problem entirely. Onward!
Anyone else discover this?
Sincerely,
Richard Martz
MagicMartz Media
Atlanta, GA
FCP 7
FCP X
Blackmagic Cinema Camera
ADOBE CREATIVE SUITE CC
Premiere Pro
DaVinci Resolve 9.0
MAC 8 core
After Effects
PhotoShop
Illustrator
Sony HD Cameras
24' Camera Crane with Motorhead
8' jib arm
20K watts of lighting
Multitrack audio
Teleprompters
Grip Truck/trailer
Location video monitoring
Door and hood mounts
Lots of other Fun Stuff!
Matthew Sonnenfeld
Re: ALWAYS FORMAT - Never simply trash files
on Jan 23, 2014 at 7:43:18 pm
I do always urge that SSD's be reformatted after use. Typically this has been found to be the best practice.
You probably did this though when you trashed the files, did you Empty Trash? If not the files are still technically on the SSD. It also may be an issue of TRIM. In SSD's, TRIM software is needed to let the computer know that files that have been emptied from the trash can be treated as garbage and written over such as would be the case in a normal HD. I'm unsure if the BMCC software has a TRIM software enabled.
Co-President at fourB Productions, Inc.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 16GB RAM
2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
Richard Martz
on Jan 23, 2014 at 9:08:49 pm
I did not EMPTY THE TRASH. So that is pretty interesting. We were recording a bunch of lengthy interviews. After 46 minutes the camera screen said SSD FULL. I thought I had 4 hours of recording time available on a 480 GB drive. I had no warning either. So that is a "gotcha" that all BMCC users should be aware of. Thanks for the explanation. Onward!
Sincerely,
Richard Martz
MagicMartz Media
Atlanta, GA
FCP 7
FCP X
Premiere Pro
DaVinci Resolve 9.0
MAC 8 core
After Effects
PhotoShop
Illustrator
Sony HD Cameras
8' jib arm
Multitrack audio
Teleprompters
Grip Truck/trailer
Anand Vyas
on Jan 24, 2014 at 1:45:58 am
Yes. One always has to format and ,make sure to eject from a Mac (else it will mess up without the eject). If using a Windows machine one can not eject for some reason but can use the files and render them before having to reformat. Basically SSD full or not, one should format on a Mac every time one is going to shoot. Exfat is best.
Richard Martz
on Jan 24, 2014 at 2:12:52 am
Why do you feel EXFAT is best? First time I have heard that. Is that for compatibiity between different operating systems?
Sincerely,
Richard Martz
MagicMartz Media
Atlanta, GA
FCP 7
FCP X
Premiere Pro
DaVinci Resolve 9.0
MAC 8 core
After Effects
PhotoShop
Illustrator
Sony HD Cameras
8' jib arm
Multitrack audio
Teleprompters
Grip Truck/trailer
