Adding looks in Speedgrade
COW Forums : Adobe SpeedGrade
Sam Bebbington
on Jan 22, 2013 at 4:01:46 pm
I've just moved my premiere pro project into speed grade. I then did a primary colour correction. I've then try to add a look to the film 'cinematic 1' to be precise and it removes my primary correction. It even takes the input saturtation down to 0.81. What is happening here, am i missing something?
Sam
Angelo Lorenzo
Re: Adding looks in Speedgrade
on Jan 23, 2013 at 12:53:34 am
Add your look to an additional grading layer above the footage.
"Looks" are, within Speedgrade, effects presets so they will overwrite your existing settings. Adding the look to a grading layer keeps it separated from your individual clip adjustments.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
