removing clips from speedgrade timeline after adding them
COW Forums : Adobe SpeedGrade
Marigna Bright
on Nov 26, 2012 at 7:53:15 pm
I recently added a couple clips in the middle of my timeline. I now dont want them, how do I 'ripple dlt' these? Ive tried comm-dlt, dlt, dragging nothing is working and cant seem to find any threads pertaining to this issue, can someone help please?
Angelo Lorenzo
Re: removing clips from speedgrade timeline after adding them
on Nov 27, 2012 at 8:29:20 pm
You cannot ripple delete. After you delete your clip, drag the next clip to fill in the time. The surrounding clips should also marry and move with the clip you are dragging. A two step process but should do what you need.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Marigna Bright
on Nov 27, 2012 at 10:32:37 pm
Thank you, figured it out, gotta hold 'shift' while dragging the rest of the timeline into place.
