Speedgrade CC Oct. Update Crashes instantly with Mercury Transmit
COW Forums : Adobe SpeedGrade
John Grilli
on Nov 11, 2013 at 9:44:08 pm
I just updated my AJA IOXT drivers to 10.4.9 and Adobe AJA Plug-Ins for Adobe Creative Cloud - Mac v10.4.8 and when I try to monitor on an external device the program crashes immediately. This renders Speedgrade CC useless! Any solutions? No third party plugins installed. Thanks, John
Bob Pierce
Re: Speedgrade CC Oct. Update Crashes instantly with Mercury Transmit
on Nov 12, 2013 at 4:34:17 pm
Yes, same thing here. In another Cow thread someone said the Aja had acknowledged the issue and were working on a fix. Hopefully it will be solved soon.
Bob
Director of Photography • Editor
http://www.lightstreamassociates.com
Chris Borjis
on Nov 14, 2013 at 12:30:32 am
I ran into this today (first time using the new SpeedGrade)
on a mac:
move /Users/USER/Documents/Adobe/SpeedGrade/7.0/settings/User_Settings.XML to reset to default SG settings (Transmit disabled)
I put mine on the desktop.
works now, but no external monitor output until aja updates it
Bob Pierce
on Nov 14, 2013 at 3:41:24 pm
Thank you Chris! Will try that today.
http://robertpiercemedia.wordpress.com
Bob Pierce
on Nov 14, 2013 at 4:57:24 pm
Yep, that worked. Thanks Chris.
Bob
_____________
Robert Pierce
John Pale
on Nov 20, 2013 at 1:37:18 pm
If you need external monitoring, you can uninstall CUDA as a workaround.
If you are lucky enough to have a graphics card that supports both CUDA and Open CL, you can switch the Mercury acceleration to OpenCL and everything will work fine...with monitoring through the Kona.
A real fix for the problem is being worked on, according to a posting by an Adobe employee on their forum.
Bob Pierce
on Nov 24, 2013 at 3:08:10 pm
Thanks John. I happen to have a late 2012 iMac and do have the option of Cuda or OpenCL, though it's not really making any difference. Really looking forward to actually being able to use this thing!
Bob
_____________
Robert Pierce
John Pale
on Nov 25, 2013 at 2:09:47 am
You have to manually uninstall the CUDA extension from your system folder and reboot. Just switching to OpenCL won't do it.
You should posting on adobe's forum, as well as on the cow. It's more closely monitored by Adobe technicians than here.
Susan Dempster
on Apr 16, 2014 at 3:38:51 pm
Any updates on this issue? I checked the Adobe forums too but no one has updated...
