Crossfades in SpeedGrade from PremierPro
COW Forums : Adobe SpeedGrade
Patrick Emerick
on Jun 21, 2013 at 10:11:26 pm
Hi everyone. I had to create a new account because I lost my old one a while ago.
Anyways. I did some searching around and couldn't find an answer to my question so here it is:
What do I do about cross fades in SpeedGrade? I just started using SpeedGrade and exported to it from PremierPro after spending time editing and create the entire video. I love SpeedGrade but it doesn't seem to handle the transitions very well. I believe that is a known issue.
What would I have to do in Premier to "unedit" all of my clips that have cross fades or dissolve to black and then export it to SpeedGrade and then when that is done edit it again in Premier to recreate all of the transitions?
I am not sure how I would go about that.
Patrick
Angelo Lorenzo
Re: Crossfades in SpeedGrade from PremierPro
on Jul 3, 2013 at 5:57:29 pm
If you are exporting DPX files from Premiere (the timeline as a whole) then you use the keyframe controls to grade through transitions.
You may want to look into EDL imports if Speedgrade supports your camera originals, as the EDLs will rebuild simple crossfades and dips to black.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
