Speedgrade only works with HD and 2K?
COW Forums : Adobe SpeedGrade
Chris Borjis
on Jun 20, 2013 at 8:06:22 pm
I was just checking out speedgrade CC.
in the setup there is no option below 720P
No SD color correction?
Angelo Lorenzo
Re: Speedgrade only works with HD and 2K?
on Jun 21, 2013 at 4:38:28 am
Speedgrade, from my experience is size independent clip-to-clip. Size is controlled mostly by output render size and your cropping/stretching selections. NTSC is available, and there are text file settings that can be tweaked to offer custom options.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Chris Borjis
on Jun 21, 2013 at 5:19:41 pm
for external monitoring on a Kona3G I'm only seeing 720, 1080 and 2k options.
I even set the aja control panel to 525i first.
It's sending it to my broadcast monitor as 1080
Angelo Lorenzo
on Jul 4, 2013 at 1:07:16 am
That I can't help you with, I'm using Speedgrade on my broadcast monitor over DVI/HDMI (I have a yet-to-be-supported blackmagic card but through extensive testing with scopes, have verified there is no color shift in my personal set up).
Angelo Lorenzo
Chris Borjis
on Jul 9, 2013 at 5:15:21 pm
thanks
