JVC GY-HM750U Record limit?
COW Forums : JVC cameras/decks
Sam Comer
on Jul 26, 2013 at 1:43:56 pm
My job uses the JVC GY-HM750U. On a couple of shoots where I needed to record longer events, I have ended up getting multiple split clips instead of one continuous clip. I shot a 22 minute presentation yesterday and I got a 14 minute clip and an 8 minute clip. I understand there is a limit on DSLR of 12 minutes/4Gb, but didn't think this was an issue with a professional, dedicated camcorder.
Is this a "feature"? Or is something set wrong?
Cards are formatted in the camera.
Mike Squires
Re: JVC GY-HM750U Record limit?
on Aug 7, 2013 at 6:31:42 pm
That is normal, even in continuous mode, it'll split clips at 4GB. This is due to the camera using FAT32 as the format type for SD cards. So technically, it's a limitation of FAT32.
Randy Burleson
on Aug 26, 2013 at 10:03:53 pm
I have experienced the same thing, but didn't know it was a limitation of the card.
I thought the separate clips should go together seamlessly but my editor informed me that there is a 12-15 frames of gap and that the 2 clips are not seamless in the recording or ingest.
Could there be something wrong with the camera or the ingest process? We are ingesting from a card reader directly into FCP X.
Mike Squires
on Aug 27, 2013 at 5:34:23 pm
I use PPro CC (and CS6) and my clips are seamless when put on the timeline.
If all else fails, I guess you could use the software that came with the camera, I believe it'll merge the clips into one large clip.
Randy Burleson
on Feb 11, 2014 at 9:45:11 pm
It's really more of a pain when you have 3 cameras that you are trying to do a Multi-cam edit on.
