GY-HD100u VIEWFINDER not working
COW Forums : JVC cameras/decks
Jon Graham
on Aug 29, 2011 at 8:16:28 pm
Just bought a used GY-HD100u. LCD works. Viewfinder doesn't light up. I know the viewfinder itself works because I put it on another camera and it worked. Is there a setting somewhere I'm missing or is the camera's brain messed up? Any suggestions?
Scott Sheriff
Re: GY-HD100u VIEWFINDER not working
on Aug 30, 2011 at 11:14:33 pm
[Jon Graham] "Just bought a used GY-HD100u. LCD works. Viewfinder doesn't light up. I know the viewfinder itself works because I put it on another camera and it worked. Is there a setting somewhere I'm missing or is the camera's brain messed up? Any suggestions?"
There is a setting that disables the VF when the LCD side monitor is opened. This can be set to this (to save battery power), or set to have the VF on when the LCD is open.
It is in the third page of the LCD/VF menu
MENU>LCD/VF>NEXT PAGE>NEXT PAGE>LCD+VF
If this is set to 'OFF' the VF will be deactivated if the LCD is open, or closed with the LCD facing out and operating.
If this is set to 'ON' both will operate all the time.
Scott Sheriff
Director
http://www.sstdigitalmedia.com
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." ---Red Adair
Where were you on 6/21?
Francisco Gonzalez
on Feb 11, 2012 at 9:47:19 am
I followed the steps you mentioned but could not find the LCD+VF pront????
