JVC 250 Image is crooked?
COW Forums : JVC cameras/decks
Chuck Pullen
on Apr 4, 2011 at 2:05:11 pm
Hello all, I am just starting to investigate a problem I have discovered with one of my JVC 250u's. It seems that the image geometry is off, and in order to get a horizontally flat image you have to tilt the camera slightly to the right. I haven't had time to investigate the problem further, but it seems that the issue is not the viewfinder, as the images shot with the camera "tilted" look fine when played back? I'm using the Fuji 17x lens btw...
Chuck
Marc Colemont
Re: JVC 250 Image is crooked?
on Apr 26, 2011 at 8:57:42 pm
I think you best take the camera to a service center. As it sounds like your CCD block is loose inside?
Are the images still sharp and crisp?
