1080 720 60 fps 19 meg
COW Forums : JVC cameras/decks
Harrison Searles
on Jan 17, 2011 at 10:02:27 pm
I Shot a Footage with a jvc 700gy shot at 1080 720 60 fps sp 19 megabits
I'm Editing on FCP 3. I set my sequence to hdv 1080 720 60.
The length of the program is 123 minutes.
I have send it to compresses to make a DVD.
Can not get to work. I have read the threads on HD to DVD
Still I can get to work.
Please help and thankyou in advance
Harrison Searles
Ron Pestes
Re: 1080 720 60 fps 19 meg
on Feb 15, 2011 at 3:10:23 am
HDV is 1440 X 1080. There is no such thing as 1080 x 720. It is either 1920 x 1080 or 1280 x 720 for HD. Drag a clip to a new project timeline and let FC pick the correct sequence setting. Then it should work.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
John Aviste
on Feb 17, 2011 at 4:44:52 pm
I am curious to know if you are able to get a high quality widescreen DVD. Is your source video 60 progressive frames per second? Just the other day I started a new thread that could be related to your problem.
Harrison Searles
on Feb 17, 2011 at 6:25:54 pm
John
The problem was a corrupt frame.
Last weekend I produce a dvd of
a Downhill ski race. The dvd look great on wide screen
Harrison
John Aviste
on Feb 18, 2011 at 2:40:32 am
Interesting. I can get a great looking widescreen DVD when the source video is 720p30 but not when it is 720p60. In both cases I am employing the same workflow, including using the same "Best" Compressor encode for DVD. I am shooting with the GY-HD200. Is your video also 720p60? If not, what is it? Do you know what I am doing wrong that would cause the 720p60 source video end up looking poorly when turned into a DVD?
Harrison Searles
on Feb 18, 2011 at 4:21:58 pm
John
I'm shooting with a Gy 700.
This camara write to FCP code on the chips.
May be your problem is ingesting the Gy 200 to FCP.
That where I would look.
I'm pretty new to FCP editing system.
Try the FCP basic forum. I have read about that problem there.
Regards
Harrison
