Clip broken into 50 - 1 to 5 second pieces
COW Forums : JVC cameras/decks
Suzanne Lucas
on Oct 24, 2010 at 3:29:06 am
I have had clips break into 1 to 5 second pieces when transfered into my NLE (Vegas 8) from my JVC HD100Ua. Everything plays back fine on the camera. It has happened a couple of times and I can not find a commen event that could be causing it, it is so random. Has anyone else had this problem and can I fix it? Help
"If you ask me what I came into this world to do I will tell you, I came to live out loud."
Will Granzier
Re: Clip broken into 50 - 1 to 5 second pieces
on Oct 25, 2010 at 9:24:39 pm
Hi Suzanne
Well i dont know much about the Vegas package, but I had this on FCP.
What I did to sort the problem on Apple was to capture as a non device control unit.. IE the software writes its own time code as it goes along. Can you do that on Vegas ? SOunds like your cams time code is going haywire at times. I had a it a few times when I was on Ver 5.1 but since Ver 6 its kinda gone
??? Hope this helps
Regards
William
