JVC GY-HM100U Telephoto Converter
COW Forums : JVC cameras/decks
Jay Mitchell
on Sep 14, 2010 at 7:18:33 pm
What are the current options for adding a telephoto converter lens to the GY-HM100U? I see that Century Optics used to sell a 1.6x 46mm converter that is now out of production. I would like to buy a 2.x if available. I saw some posts where step-up filter rings were being tested with 58mm telephoto converters.
Jay Mitchell
http://www.FootageWorks.com
http://www.ActionStockPhoto.com
Will Granzier
Re: JVC GY-HM100U Telephoto Converter
on Sep 26, 2010 at 4:40:19 am
Hi Jay
If I may ask what do you want to shoot - I have HDY 101's and have the fujinon adaptor rings that I purchased. It allows you to go from a 1/3 inch (standard lens )to a half inch lens.
I then got myself 2 old Fujinon Pegasus 2 lenses with doublers on.
The good thing is that using the fujinon lens converter - it gives you a x 1.8 just by fitting the doubler. So your std 14 x goes to about a 25 optical... Then add the doubler on the lens and you go to a 50 x
I shoot lots of sport action and wildlife and it works for me.
The Pegasus 2 lenses are fairly cheap. They came std with the Sony BETASP cams pre 1999. Rocksolid, Cheap and easy to get yr hands on
Try and stay away from converters that screw onto the front of your lens. Filters are great but converters tend to distort the images especially on the edges. Shooting in 16:9 its no good
Hope it helps
William
Regards
William
