JVC ProHD camcorder output to SDI
COW Forums : JVC cameras/decks
Eddy Pribeagu
on Mar 3, 2010 at 9:54:21 pm
Hi... im currently using JVC ProHD camcorders ( GY-HD110 ) and if anyone can help on what is the best way to get an output to SDI... The outputs on the camcorder now are only IEEE 1394/HDV/DV , component , and composite. Im planning on filming in 720p and the feed will be sent to a video mixer via SDI... thanks for any help!
Piotr Niemcewicz
Re: JVC ProHD camcorder output to SDI
on Mar 4, 2010 at 7:57:25 pm
analog component to digital component
http://www.aja.com/products/converters/converters-hd-hd10ava.php
Mark Petereit
on Mar 5, 2010 at 12:16:34 am
I have that exact camera and use the BlackMagic Analog to SDI miniconverter. Works flawlessly!
And at $470, it's about $500 cheaper than the AJA.
Mark
Marty Dashiell
on Nov 25, 2010 at 2:39:35 am
Have you encountered the issue of powering your Black Magic via anton bauer power tap and not having the unit operate properly with a fully charged Lithium Ion battery? I had heard some discussion about the unit needing constant 12v power supply and not a flexible range of power that is encountered with using the camera battery as its power source. Curious as to your workflow and application with the device as I am considering a purchase.
Marty
Mark Petereit
on Nov 25, 2010 at 2:21:10 pm
Nope. Since my cameras are all stationary (on tripods in our church's sanctuary) I run all A/C power.
Eddy Pribeagu
on Mar 5, 2010 at 2:36:19 am
Thanks alot guys.. but i was also wondering if i would get better quality converting HDV through the IEEE 1394 port to HD-SDI, since there both digital, instead of from component... what do you guys think?
cowcowcowcowcow
Mark Petereit
on Mar 5, 2010 at 11:25:02 am
You DEFINITELY want to convert from the component out -- it's uncompressed analog. If you go Firewire out, your video is going to get reduced in quality a bit due to the HDV compression and it will come out with a significant delay.
Eddy Pribeagu
on Mar 5, 2010 at 2:55:26 pm
Thanks alot!.. thats the answer i was looking for..
Piotr Niemcewicz
on Mar 5, 2010 at 7:31:46 pm
only component!!!
by firewire reduced color sample rate to 4:2:0 (pal) and bit rate reduced to 19 Mbs, and imposition HDV codec (terrible)
by component (analog or digital) you have color sample rate 4:2:2 (broadcast) full band of quality, and NO codec.
After converter you should be connect to NANO Flash.
http://www.convergent-design.com/
Mark Petereit
on Mar 5, 2010 at 10:26:36 pm
Wow! $2895 for a Nano Flash? You could buy a whole Mac Pro workstation for that. ;-)
Piotr Niemcewicz
on Mar 6, 2010 at 8:57:52 am
you lucky man
only 2895 $..
in Europe + 22% VAT and $$ for duty
Mark Petereit
on Mar 6, 2010 at 3:16:23 pm
I don't know why you put up with that. But then I guess we Americans have a reputation for "handling" out of control taxes. ;-)
Piotr Niemcewicz
on Mar 6, 2010 at 5:52:24 pm
yes i know :)
smart guy
