HM700 w/Fuji17X need filters
COW Forums : JVC cameras/decks
Doug Calhoun
on Feb 19, 2010 at 9:47:45 pm
Hi all,
I'm looking for a 82mm UV/Clear HiDensity filter that will fit the HM700 with the Fuji 17X and allow the hood to be removed without removing the filter. Ideally one that allows a CP filter to be stacked as well.
Any in put is appreciated.
D
Piotr Niemcewicz
Re: HM700 w/Fuji17X need filters
on Feb 20, 2010 at 10:41:47 pm
B+W
99,8% of transparency
Doug Calhoun
on Feb 22, 2010 at 4:37:15 pm
Thanks Piotr. The Formatt I was sold is a nice filter but I have fat fingers and struggle to work up inside the hood to attach the CP after removing the UV/Clear which you can't stack on. Seems dodgy for the work I do nearly all outdoors in all conditions.
To be sure, the B&W you mention, is it the standard depth or slim? A second filter can be stacked, correct?
Piotr Niemcewicz
on Feb 23, 2010 at 11:51:46 am
this filter is more "transparency cap", nothing change in picture, clean and clear
a have several cameras, and on jvc i have B+W,
its not more expensive and very good glass.
