frame and bit rates
COW Forums : JVC cameras/decks
Keith Betts
frame and bit rates
on Dec 11, 2009 at 4:09:58 am
I've heard from several sources that 1280 x 720 has been the preferred resolution to shoot in with the JVC GY-HM700 but what about frame and bit rate? My next gig is a dance performance including everything from ballet to hop hop. Any recommended frame rate settings for that type of action? I'll be shooting a 3 hour show on one day and four 1 hour shows on another so I'm also trying to keep the number of SDHC cards needed to a minimum plus I'll be compressing to SD to distribute dvd's for sale.
Ryan Mast
Re: frame and bit rates
on Dec 11, 2009 at 3:21:55 pm
If you're delivering in standard def, you'll be fine with the lowest bit rate, especially since you're not going to have a lot of full-screen motion that would require more data. If you're in a situation where you're doing more camera motion with a highly detailed background, you'll see the difference in a higher bit rate.
If you want to deliver it on DVD as 60i, shoot 1280x720 60p. If you want to deliver it as 30p, shoot 1280x720 30p.
