outputting timecode on HD110U
COW Forums : JVC cameras/decks
Matt Ruggles
on Nov 6, 2009 at 10:35:22 pm
I want to make DVD timecode dubs to DVD to do an off-line EDL. I recorded footage in 720/30P
2 Things:
1. I can't get it to output in letterbox as it is in squeeze mode and won't let me change it. I would much rather view it in letter box mode if possible.
2. There has to be a way to display camera data to an external monitor and I am not finding it. Specifically I want timecode displayed so I can make notes on what is shot based on timecode.
Any help with either of these 2 questions would be great.
Matt Ruggles
Scott Sheriff
Re: outputting timecode on HD110U
on Nov 7, 2009 at 4:41:07 am
Matt
Are you trying to record video out from the camera right to a DVD recorder?
Give me a call or email if you can't find the #, I have this cam and a BR-50 deck. I'm sure I can help you out. probably just the switch settings.
Scott Sheriff
on Nov 7, 2009 at 5:04:34 am
Quick help
Menu-other
ouput char set to on
When the output char is set to on, the composite video out mimics the VF/LCD display. Toggle the display (display toggle button)to show the TC if it isn't up. Make sure the TC/UB menu the TC is also set to ON.
Set the Video Format menu-HD PB Output to what your looking for.
PB Tape-Auto
Output Terminal-Auto
This should give you composite out from the RCA composite gizouta
970.433.5994
