JVC GY-HD100 using HDV, and its compatibility with AVID Media composer
COW Forums : JVC cameras/decks
Andrew Hagan
on May 29, 2009 at 1:34:09 pm
I have recently upgraded my Avid Express pro with Avid media composer. I am using my JVC GY-HD100 camera to capture the footage. Using the camera on Standard def it works fine. However when I try to capture footage in HDV, the computer tells me there is a communication error. Any info would be great.
Andrew Hagan
Edgar Mills
Re: JVC GY-HD100 using HDV, and its compatibility with AVID Media composer
on Jun 2, 2009 at 5:03:27 pm
I have a similar post. Please lets keep each other informed on any new results
thanks
Paul Lewis
on Jul 13, 2009 at 3:42:54 am
The easiest way I have found it use a free utility called HDV Split.
You can get it here
http://strony.aster.pl/paviko/hdvsplit.htm
Then import the file it creates from the camera.
I use Avid Media Composer Adrenaline 2.8 with this and it works,
plus you can convert the footage to Avid DNxHD codec.
Hope that helps
Cheers
Paul Lewis
