possible to capture non-59.94fps footage into Final Cut?
COW Forums : JVC cameras/decks
Bobby Mosaedi
on Jan 15, 2009 at 11:46:24 pm
We shoot a lot of material with the JVC camera in 24p/23.98 and acquire using a HDMI to HD-SDI converter to capture the footage into final cut. The only problem I have is that I hate having to capture nearly three times the amount of frames, then having to use compressor to re-encode everything. Big pain. Does anyone have a non-HDV workflow that allows you to capture JVC 720 footage either at 24/23.98p or 29.97p? thanks
Bobby Mosaedi
Magic Video, Inc.
Johnny Clark
Re: possible to capture non-59.94fps footage into Final Cut?
on Jan 29, 2009 at 3:56:07 am
What camera are you using?
Bobby Mosaedi
on Feb 5, 2009 at 5:22:53 pm
Im using the JVC GY- HD250's HD-sdi output into a AJA LHe using AJA quick capture or FCP 6.0.5 with a HD Connect HDMI-HDSDI converter.
Bobby Mosaedi
Magic Video, Inc.
Bobby Mosaedi
on Feb 5, 2009 at 10:41:22 pm
Ok, I figured it out... need to select the 1280x720 VFR instead of 1280x720 59.94 and just select the desired frame rate. Hooray!
Bobby Mosaedi
Magic Video, Inc.
