JVC GY-HD100U Problems
COW Forums : JVC cameras/decks
Carolin Fox
on Oct 8, 2008 at 4:09:10 pm
someone can explain to me about distortion in the video
type linesman arranged the focus back but I can not find solution
I appreciate very much
Ed Dooley
Re: JVC GY-HD100U Problems
on Oct 8, 2008 at 4:56:28 pm
Ola Carolin,
No hablo español muy bien, y entiendo muy poco, pero usted no está explicando el problema lo suficientemente bien como en Inglés. Cuéntanos más.
In English please, what distortion?
Gracias,
Ed
[Carolin Fox] "someone can explain to me about distortion in the video
I appreciate very muc"
Carolin Fox
on Oct 9, 2008 at 10:56:50 pm
the word is distortions
Or type vibrations per Example when I
panning according to wed in some cities talk about this and blame the
Lens
Carolin Fox
on Oct 9, 2008 at 11:02:11 pm
Lens
cowcowcowcow
Ed Dooley
on Oct 10, 2008 at 4:08:05 am
Sorry, I still don't understand the question. Is Spanish your language? Lo siento, pero yo aún no entiendo el problema. Pregunte en español. Tal vez pueda comprender mejor en español.
Ed
Carolin Fox
on Oct 10, 2008 at 3:46:08 pm
OK una ves mas Tratare de explicarles
Por fabor Vean esta Pagina ALLi tengo un ejemplo de video
donde podran ver el problema Les Agradecere Su Respuesta
Gracias http://www.mogulus.com/esperanza2009
Ed Dooley
on Oct 10, 2008 at 4:09:28 pm
Basically guys, Carolin's link explains it all:
Up and down motion is creating jaggies (more severe than regular interlacing jaggies). Could it be a shutter speed/frame rate issue?
Carolin, what are the camera's settings? Is it HDV or SD? Is the Frame Rate 24, 25, 30?
What is the shutter speed?
Ed
Carolin Fox
on Oct 10, 2008 at 7:42:59 pm
En Los dos SD and HDV 30 Frame Rate
shutter speed Es 1/60 Vean el Video
Ed Dooley
on Oct 10, 2008 at 7:49:24 pm
The video is 16x9? It looks much wider. Did you stretch it while editing or compressing?
Ed
Y el vídeo es 16x9? Parece mucho más amplio. ¿Lo que se extienden cuando se edita?
Carolin Fox
on Oct 10, 2008 at 3:57:00 pm
Ok Tratare de explicarles una ves mas
Les Agradecere Mucho por su pronta Respuesta
Por favor viciten esta pagina ALLi Tengo un Ejemplo de viveo
y Podran Ver el problema
Ed Dooley
on Oct 10, 2008 at 4:51:17 pm
Carolin,
Your video looks very wide, not 16x9. Have you stretched it or done something to it while editing?
Su video se ve muy amplia, no 16x9. ¿Ha estirado, o hacer algo para que durante la edición?
Ed
Carolin Fox
on Oct 10, 2008 at 10:43:51 pm
Este Es Otro Video DV 720x480 Ratio 4:3 Frame Rate 29.97fps
Vean el Link http://www.mogulus.com/esperanza2009
Ed Dooley
on Oct 10, 2008 at 11:06:10 pm
Veo que hay detrás de vídeo el título en la parte inferior. Sin embargo, el título dice que es DV60i, no 30p. Si es 60i entonces es entrelazado y que es lo que estamos viendo. Tienes que de-entrelazado de vídeo. Lo siento por mi Español.
Oh, I see, there's video behind the title at the bottom. The video is 60i not 30P. You're seeing interlacing. You have to de-interlace it for the web.
Ed
