JVC's GY-HD110U Capture with other Camcorders
COW Forums : JVC cameras/decks
joaquin ruano
on Jul 16, 2008 at 6:10:38 pm
i shot some footage with JVC's GY-HD110U, but that camera was rented and it was very expensive, for the capture im can get other hd cameras for free, but i have having trouble capturing or reading the tapes.
my question is: is it posible to capture material shot with this camera using another brand camera or deck and if so which is it.
thanks
joaquin
Chris Borjis
Re: JVC's GY-HD110U Capture with other Camcorders
on Jul 16, 2008 at 11:42:35 pm
Sony HDV decks will play the JVC Tapes in 30p and apparently 24p will also capture but you will not see it on the lcd.
joaquin ruano
on Jul 17, 2008 at 3:42:23 am
i tried on a sony deck and could not read it and also tried on a canon xl and could not even play it on its play back.
any body else got any sugestions
thanks for the response Cris
Chris Borjis
on Jul 17, 2008 at 7:56:47 pm
you played HD110 recorded HDV tape to a Sony HDV deck and it didn't work at all?
It definitely should, are you sure it was set for HDV?
The Auto setting does not work well on the sony HDV decks.
Claes Lilja
on Jul 21, 2008 at 10:38:54 pm
I have a similar issue that I am dealing with. I am trying to capture JVC footage with a Sony deck into FCP. I see the timecode, but the screen stays black.
Chris Borjis
on Jul 22, 2008 at 7:14:46 pm
did you go into the sony deck menu and switch
the DV/HDV switch to HDV?
if its on AUTO it will not work.
Claes Lilja
on Jul 25, 2008 at 3:08:53 am
Yes, I set the switch to HDV. I am able to capture footage shot on my Sony V1U in 1080i without any problems. When I put the tape with the JVC footage in the deck, it will play out to the monitor connected directly to the deck, but in my FCP Log and Capture window I only have a black screen. I do see the timecode and I can still control the deck from the L&C window within FCP.
Chris Borjis
on Jul 25, 2008 at 4:27:05 am
are you connected via firewire?
I have not tried that, but I know the component outputs should work if you have an aja or black magic capture card.
Claes Lilja
on Jul 25, 2008 at 9:59:42 pm
I am connected via firewire. Not sure what is in the computer. I'm on the 2.8GHz Intel Core 2 Duo iMac.
Chris Borjis
on Jul 28, 2008 at 10:42:57 pm
ah, thats why its not working.
you might have to find someone with that deck and provide
a hard drive to capture to.
I have one, but I'm in Oregon.
Claes Lilja
on Jul 28, 2008 at 11:19:08 pm
I was hoping to avoid that. So the issue is with the iMac hardware not being able to process the signal through firewire?
Claes Lilja
on Jul 28, 2008 at 11:39:16 pm
Would I be able to capture it if I took my SONY deck, JVC footage and used it on a different mac?
Chris Borjis
on Jul 29, 2008 at 9:39:28 pm
no, you have to have a JVC deck to capture this over firewire and your imac would have to be at least a dual G5 to edit smoothly.
Claes Lilja
on Jul 29, 2008 at 11:13:55 pm
Ouch! Thanks. I guess I have to find a deck to borrow somehow. As for the computer, the dual Intel core 2.8 with 3GB of RAM should suffice, right?
Chris Borjis
on Jul 29, 2008 at 11:40:11 pm
[Claes Lilja] "As for the computer, the dual Intel core 2.8 with 3GB of RAM should suffice, right?"
yeah that should work just fine.
Claes Lilja
on Jul 30, 2008 at 12:04:40 am
Thanks!!!
