Anyone with a HD110, HD200, or HD250
COW Forums : JVC cameras/decks
James Cordell
on May 14, 2008 at 1:47:43 pm
I need to know if anyone that owns or has used one of the above cameras has used a litepanel mini plus with it. I am wondering what length of articulating arm I should get. either a 8.3 inch or a 4.3 inch. I want the light to reach down and sit just above the lens but not hang over. Also will be using the 13x with the camera which sticks out farther than the 16x. Anyone with experience with this kind of setup your input would be appreciated. Thanks
Gary Brown
Re: Anyone with a HD110, HD200, or HD250
on Jul 16, 2008 at 6:26:53 pm
Well sort of!
I have several HD250Us and use a litepanel Mini on an NOGA 10" Israeli arm. I put the light at the top of the lens for close up or macro work. However it will reach nearly 2" past the 16.5x lens. Hope that helps!
GB-)
"Better, Faster, Cheaper ... Pick Two!"
Gary R. Brown, SCVE
Video Systems Engineer
Portsmouth Public Schools
Portsmouth, Virginia
23704-2135
James Cordell
on Jul 17, 2008 at 1:40:45 pm
Hey thanks for your reply. That helps. I actually had a chance to check the fit on an actual camera since the time I wrote this post. Thanks again.
