Clogged Tape Head
COW Forums : JVC cameras/decks
Matt Burrows
Clogged Tape Head
on Mar 26, 2008 at 2:15:08 pm
Hi Everyone,
I've had a new problem pop up with my GY-HD110. I've been trying to dub some raw footage over to DVD. Before I get to the end of any 63 minute tape, the "Head Cleaning Required!" warning starts to flash on the LCD monitor. I stop the dub, break out the JVC Cleaning Tape and use it in the deck of the GY-HD110. This seems to fix the problem for about 30 minutes and then the same "Head Cleaning Required!" warning pops up. The head only has 91 hours and this is happening a lot. Any ideas? Does the head need to be cleaned by a pro? Where can I find a JVC authorized service center in Columbia, SC???
johnny clark
Re: Clogged Tape Head
on Mar 26, 2008 at 3:36:36 pm
Sorry to hear that you're having problems.
Have you checked out the actual tape that you're capturing from?
Sometimes if the tape even has a small stretch it can glitch.
Sounds like you're doing everything right though with cleaning and all...
Is your 110 still under Manuf. Warranty?
Johnny C
© 2018 All Rights Reserved
