Has anyone done PAL on the HD100?
COW Forums : JVC cameras/decks
Tim Baker
on Jan 31, 2008 at 2:11:26 am
Hey all,
Has anyone shot PAL on the HD100 in the US and if so how did it work and did you have any workflow issues?
Tim Baker
Chameleon Mobile Video Productions
"It is not the light at the end of the tunnel that we should is the courage to take the next step in the dark that we must find."
Peter Ward
Re: Has anyone done PAL on the HD100?
on Feb 9, 2008 at 2:14:39 am
Hi Tim,
In HDV mode 'PAL' is no big deal and you don't even need a PAL camera--just shoot in 25/50p and use the appropriate timeline in your NLE.* In DV mode you'll need a PAL model, and all of the same implications apply as would with any miniDV camera. I would advise against mixing 25/50p material with 30/60p material, however, as the framerate conversion can sometimes produces weird effects.
*One caveat: shooting 25 or 50 fps (in any formant including film) in a country such as the US were the mains power (AC) is 60 cycle can result in lights appearing to flicker--you'll have to adjust the shutter speed to eliminate this; in general, reducing the shutter speed should solve the problem. Of course, you'll be able to see this in the viewfinder.
MacBook Pro Intel Core Duo 2GHz
Final Cut Pro 5.1.4
© 2018 All Rights Reserved
