HD100 question about PAL and HDV
COW Forums : JVC cameras/decks
shamgod
on Oct 23, 2007 at 10:22:04 pm
The JVC HD100 shoots in a SD/HDV mode of 25p and 50p at 576. Is this a PAL signal or does the HDV codec make it agnostic?
Suppose you originate in 25p/576 and output to DVD, will it play on standard DVD set top player? Can it play on a NTSC set?
Tim Baker
Re: HD100 question about PAL and HDV
on Nov 7, 2007 at 7:00:02 pm
If I'm not mistaken here...once you output to the .mpeg compression for DVD...it should play just fine on any DVD player.
Even most EU players are cross compatible with pal/ntsc as long they were made in recent years.
Not sure about the other questions.
Tim
serleejus
on Dec 1, 2007 at 1:22:39 am
Hi, 25i or 25p 576 lines is PAL. it is all 50hz. But the DVD playback question - many now will play either PAL or NTSC. Just check because some large mfg's will lock it to only NTSC. Lite on, Apex, many OEM players will play both.
