BRHD50 to SDI workflow problems
COW Forums : JVC cameras/decks
morten Ranmar
on Sep 16, 2007 at 6:36:40 pm
I am using FCP 6 with a Kona 2 card to digitize from the BRHD50's component out via an AJA component to SDI adapter. Problem is that the 720P 25fps footage from my HD100 comes in as slowmotion - as if tit was shot in 50fps? Tried to alter the Konas easy setup but problem remains. Want to avoid native HDV editing, but can't seem to get the workflow to work!?
- No Parking Production -
Finalcut Studio, Dual G5, Kona 2, X-Raid
Justin Ferar
Re: BRHD50 to SDI workflow problems
on Sep 17, 2007 at 7:55:51 pm
This is definitely a Kona issue. You'd have better replies from the AJA forum. I use Black Magic so I can't help you there.
