HDV - mini-dv tapes
COW Forums : JVC cameras/decks
matt sherman
HDV - mini-dv tapes
on Mar 28, 2007 at 2:34:13 pm
I keep getting differing answers on this, but to record HDV can you use a normal mini-dv tape or do they have to be HDV specific?
cowcowcowcowcow
Justin Ferar
Re: HDV - mini-dv tapes
on Mar 28, 2007 at 8:05:23 pm
There is no difference which is the beauty of HDV cameras- no need for specialized tape. Whatever you do- just make sure to pick one brand/type and stick with it. Different brands have different lubricants which by switching will gunk your tape heads.
EVA-O2a
on Mar 30, 2007 at 7:23:07 pm
Not to change topic, but on the lubricant issue - it's ok if you use different kinds of tapes from the same manufacturer right? I've been wondering about that, I have two different types of Panasonics...
Justin Ferar
on Mar 31, 2007 at 12:51:32 am
I can't say yes with absolute certainty because there may be exceptions but in general you are correct. Brands stick with the same lubricants.
EVA-O2a
on Mar 31, 2007 at 3:56:01 pm
Yeah, I thought they probably would. Thanks!
