Remove camera path
COW Forums : Syntheyes
Tomek Dyszkiewicz
Remove camera path
on Oct 1, 2015 at 8:28:04 am
Hi, I have a complicated scene and after solving at certain point whole scene offsets for one frame. I suppose it is due to some invalid traceker. I would like to disable camera path and see trackers movement (unlinking camera that is in motion after solve). How to do that?
It is urgent, please.
brian morse
Re: Remove camera path
on Oct 1, 2015 at 2:42:50 pm
Hi Tomek,
If I understand what your trying to do you basically want to interpolate the camera for the one frame where the camera offsets. Here are a couple options. One is in the features tab there is a button to skip frame, that will skip the frame during a solve. The other is to go into the graph editor, when you already have the solve, click on the camera go to the Solved path and delete the keyframes for that frame.
Brian
