Tracker's host reassign
COW Forums : Syntheyes
Tomek Dyszkiewicz
on Dec 13, 2014 at 10:46:01 am
Hello, I am just getting to know Syntheyes and probalby buy it instead of more expensive PFTrack because it seem to meet my expecations.
The problem I came across is changing tracker's host - I was adding manual trackers on camera01 but just accidentaly I created New Moving Object and following trackers were added to that host. I can't find a way to reassing trackers from object01 to camera01. Could anyone help please?
brian morse
Re: Tracker's host reassign
on Dec 13, 2014 at 8:05:50 pm
Go to the coordinates tab. Select the tracker and then on the side just above where it says "Seed and Lock" there is a drop down it will probably say Object 01. Select that and change it to Camera. A pop up will come up and ask if you wan to clone or copy. select which you prefer and you should be all set
