[Syntheyes 1311] Lens Correction and Lens Workflow...
COW Forums : Syntheyes
Duca Simone Luchini
on Jul 25, 2014 at 12:18:27 pm
Hallo everybody,
If you apply Lens distortion, (by Image preparing/Lens/ apply presets, or by Lens,/Calculate Distortion) - before make you tracking process, you are transforming your original distorted plate in a undistorted plate. This can improve drastically your track and should be always done.
At the and of the process, you can Export your tracking data and save the undistorted sequence WITHOUT applying Lens Workflow, cause our plate is already undistorted and the tracking data are calculate on this undistorted plate.
ONLY if you don't use any Lens correction, and make your tracking process on the (distorted) original Plate, at the end of the tracking process you CANNOT export your tracking data, but you must make a Lens Workflow, if you want an undistorted plate as correct reference image plane for 3d your application, to match correctly the 3d meshes (always undistorted in the 3d software) with the plate, and than, NOT BEFORE, export your tracking data as well, otherwise you'll have a undistorted plate BUT a distorted tracking data...
I don't know if are agree or not...
