Syntheyes and GH5 Back End Sensor size calculation
COW Forums : Syntheyes
Giorgos Othonos
on Apr 1, 2019 at 3:19:59 pm
GH5 Back end sensor size.
Hello i am trying to calculate the correct back end sensor size of the GH5 but after the least firmware updates i am not sure what is corrects anymore.
Usually to find the correct back end sensor i do the following math:
To find the width.
3840 ÷ 1920 = 2
3840 ÷ 2 = 1920
17.3 ÷ 2 = 8.65mm
To find the high.
2160 ÷ 1080 = 2
2160 ÷ 2 = 1080
13 ÷ 2 = 6.5mm
So for the 1920 x 1080 the actual back end size is 8.65mm x 4.85mm
My data until now:
Max video resolution :3840 x 2160
Sensor Dimensions: 17.3 mm x 13 mm (0.68 in x 0.51 in)
From: https://www.digicamdb.com/specs/panasonic_lumix-dc-gh5/
Sensor size: Four Thirds (17.3 x 13 mm)
Sensor type: CMOS
Sensor resolution: 5196 x 3907
Max. image resolution: 5184 x 3888
Max. video resolution: 4096x2160 (24p) (C4K)
But how is possible that when I record in 4096 x 2160 the size of the sensor stays the same ?
Questions
1. When i record in 3840 x 2160 is the GH5 using a smaller part of the full 17.3 mm x 13 mm (0.68 in x 0.51 in) sensor? And if yes what is the actual size ? or how i can calculate that ?
2.When i record in bigger resolution like the 4096 x 2160 what is happening to the sensor ? is using a different aspect ratio ? or is this the actual full back sensor ?
3. And what is actually happening to the sensor when you record 6K anamorphic (4,992 x 3,744)?
4. Is the real size resolution based on the amount of pixels that are in the Photo mode Instead on the Video mode ?
Thanks in advance.
Also the reason i am asking all this questions is because i am a vfx student and am currently working with syntheses for taking data .
