Auto add preset name to file name?
COW Forums : Adobe Media Encoder
Conrad Olson
on Jan 4, 2014 at 10:03:45 pm
Is it posible to setup Media Encoder to add the name of the encoding preset (or part of it) to the filename that it outputs?
For example I have been working on a sequence called "Showreel" and I want to encode multiple version of the same sequence using presets. Ideally I would add it to the queue, add one preset, and set the destination. Then I could add other presets that encode to the same folder but with different prefixes so I end up with something like:
showreel_ProRes.mov
showreel_iTunes.mp4
showreel_Vimeo.mp4
showreel_YouTube.mp4
At the moment I have to manually add the name of the preset myself.
conradolson.com
Jed Ivie
Re: Auto add preset name to file name?
on May 5, 2014 at 9:02:26 pm
Did you ever find a solution to this question?
Conrad Olson
on May 5, 2014 at 9:21:49 pm
No. I'm afraid note.
conradolson.com
André Thijsen
on Mar 1, 2017 at 9:08:08 am
https://helpx.adobe.com/media-encoder/using/using-preset-browser.html
Y ou can make it via "Ingest Presets"…
