23.98 to 29.97 convertion in media encoder?
COW Forums : Adobe Media Encoder
Ali Quintana
on Nov 25, 2013 at 10:28:03 pm
Is that possible? I have 2,5K footage in 30 sec in AE prjct file. I precomp it to 720 by 480 ntsc but still at 23.98 frames.. Will render this in Mov..
Can the media encoder do the convertion from 23.98 to 29.98 without problem?
These are the broadcast specs:
Settings for encoding programs/ commercials
Video
Codec: MPEG 2
Quality: 5
TV Standard: NTSC
Frame rate (fps): 29.97-drop frame
Field order: Lower
Aspect ratio: 4:3 (720 x 480 pixels)
Bitrate settings: CBR (Constant Bitrate)
Bitrate (Mbps): 6 Mbps
Audio
Audio codec: MPEG-1 Layer II Audio
Mode: Stereo
Sample size: 16 bit
Frequency: 48 kHz
Bitrate (kbps): 224 Kbps
Ryan Holmes
Re: 23.98 to 29.97 convertion in media encoder?
on Dec 1, 2013 at 10:33:49 pm
Yes, AME can do frame rate conversions. You may have to adjust settings to get your desired look, but Media Encoder should get the job done.
Other products that can do it: Apple Compressor, Apple Cinema Tools, Sorenson Squeeze, Telestream Episode.
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Ali Quintana
on Dec 2, 2013 at 7:17:01 pm
Question, what if I just precomp it in AE into a 29.97 comp and rerender.
will i get a 29.97p conversion?
