from 1-2 hour export times to 10+ hour export, 15 min file.
COW Forums : Adobe Media Encoder
Greg Burke
on Oct 11, 2013 at 6:27:22 am
Hey guys so I'm exporting a .mov from CS6 the Raw footage is h.264 1080, I added 2 filters Fast color correction, and Three way color, I have a Jpeg on the timeline over the footage as well. I've exported allot of these things, they mostly all take the same amount of time 1-2 hours for a 15min long output, However this time its taking 10+ hours? this doesn't make sense to me at all, any help? Below are the RAW and Export Settings
RAW
Canon 5D Mark III (H.264, 1920x1080, 24fps)
Output
1920x1080
H.264
VBR, 2 pass, Target 5.00 Mbps, Max 6.0 MBps
AAC 192, 48hz
Thanks in advance!
CS6, Mac OsX
2.26ghz quad core 16gigs RAM
I wear many hats.
http://www.gregburkepost.com
Ivan Myles
Re: from 1-2 hour export times to 10+ hour export, 15 min file.
on Oct 11, 2013 at 10:58:57 am
First verify whether GPU acceleration is enabled. Second, did you enable Maximum Bit Depth or Maximum Render Quality in the export settings?
Greg Burke
on Oct 11, 2013 at 8:22:57 pm
Well, I've exported a ton of this sequences prior,and haven't had this problem until now, and No Maximum Render Quality isn't on. I don't have a Nvidia Card I have a AMD card so no acceleration for me.
I wear many hats.
Greg Burke
on Oct 11, 2013 at 10:48:33 pm
I actually figured out the problem, I had taked CR2 images and saved them as jpgs, but I didn't change the resolution which was about 3500x4500, and CS6 was having issues rendering it out.
I wear many hats.
