Encoding for Blu Ray
COW Forums : Adobe Media Encoder
fernando zuniga
on Jun 4, 2013 at 5:34:09 am
Hey guys. I have a project that I've filmed in HDV and i'm burning it on a Blu Ray and its 55min long.
What presets do you guys recommend ?
Kris Merkel
Re: Encoding for Blu Ray
on Jun 4, 2013 at 1:49:56 pm
Start with the Blu ray presets in AME. It is really very difficult to sugest specific settings when discussing encoding because each video piece may require something different other than just setting bitrate for the length of the program.
YOur best workflow will be starting with the presets, as they are fairly good, and then tweaking your bitrate and other parameters to obtain the optimal encoded image. Remember you re balancing between quality and length of encode and that once you hit a certain threshold very small improvements in image quality can add an extraordinary amount of time to the processing.
Start with a small chunk to test your settings and you can then calculate an approximate time at specific settings.
"Think of everything in terms of building capacity."
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com
2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W
