Black Video Attached to Tail End
COW Forums : Adobe Media Encoder
Scott Wild
on May 31, 2013 at 5:03:57 pm
Exporting PPro CS6 sequences through AME, in multiple sets of preset export settings. All in h.264 at various resolutions and bitrates. All of the sequences default to encoding the entire sequence, and yet on export all of the videos have a black video tail of 10-20seconds. The work area was and remains set to precisely the end of the footage in the sequence, and there are no tailing clips.
In other words, I can't find where this tail is coming from. Any help would be much appreciated.
Kris Merkel
Re: Black Video Attached to Tail End
on May 31, 2013 at 5:27:00 pm
Are you sure that there is nothing after the work area. Or have you checked the box that asks to export the work area only.
AME will not add blank space video to the end of your sequence.
"Think of everything in terms of building capacity."
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com
2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W
Scott Wild
on May 31, 2013 at 5:30:48 pm
You bet. The sequence is clean as a whistle, and the work area is set precisely. I'll be running it again, but it's a 5-hour export.
Kris Merkel
on Jun 3, 2013 at 1:43:09 pm
Don't bother exporting the entire sequence, set your work area to just the tail 30 seconds and export that to see if it is the tail or something else in the file that is causing problems.
You are troubleshooting which means you need to isolate variables until you find out exactly what is causing the problem so you can fix it.
Encoding the whole sequence again hoping that it will turn out differently would be defined by some as insanity. Especially if it is going to set you back 5 hours
good luck.
Kris Merkel
2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
