encoding to MPEG2 with PCM 24bit audio
COW Forums : Adobe Media Encoder
Tom Smith
on May 25, 2013 at 12:31:26 pm
Hello!
I have some requirements from a tv station and can not manage to find the right settings in adobe media encoder.I am mainly failing to find PCM 24bit audio with the MPEG2 Encoder.
The required settings are the following:
- Video:
HD (XDCAM HD422 1080i25 compatible): MPEG 2, 50 Mbit/s, constant bitrate,
1920x1080 25i (4:2:2 PROFILE@HIGH LEVEL),
containerformat .mpg, .mxf or .mov
- Audio:
linear PCM, 24 Bit / 48 kHz. ,stereo
Maybe someone can help me out a bit.. I would very much appreciate it!
Kris Merkel
Re: encoding to MPEG2 with PCM 24bit audio
on May 29, 2013 at 1:22:55 pm
As you have probably seen from the Forums on Adobes site that this is not possible with AME. You will have to use Episode or Compressor if you have it.
"Think of everything in terms of building capacity."
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com
2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W
