Blu-ray H264 encode dissolve artifacts
COW Forums : Adobe Media Encoder
Timothy Gassen
on Feb 5, 2013 at 6:49:29 pm
We are authoring our first Blu Ray with Adobe Media Encoder 6, and need some suggestions -- so thank you for any and all help!
We are encoding SD 16x9 MJPEG files to H264, using Encoder's "Legacy SD" preset, 2-pass VBR at a target rate of 8mbps. (We need to fit @11 hours of SD video on a BD, and we will make it a 50GB dual-layer if need be.) This setting is actually the first that we've found that outputs the correct SD field-dominance and is accepted into Encore without transcoding.
Encode quality is generally good, but we get "winking" of video or break-up artifacts in dissolves and during fast-action, and some undulating during still video images.
We are not experienced encoders, and after a lot of searching here and elsewhere we are guessing we need to adjust/disable key frames, try Constrained VBR, etc -- any specific suggestions are appreciated.
Since there are very few ways to change this pre-set in Media Encoder, is it possible to copy the pre-set values to edit as a new setting?
Thank you again for any help!
Timothy Gassen
Director/Producer
http://www.purple-cactus.tv
