Exporting AVI from a Mac
COW Forums : Adobe Media Encoder
Mandla Bolekaja
on Jan 31, 2013 at 11:25:40 pm
How do I export an AVI file from a Mac?
Using CS6, Media Encoder 6.0.2 on Mac OS 10.8.2.
M
MB
2.8 Quad-Core, 18 GB Ram, CS6, Mountain Lion
Todd Kopriva
Re: Exporting AVI from a Mac
on Feb 1, 2013 at 5:26:59 am
Install Flip4Mac or a similar utility to give QuickTime the ability to create AVI files.
After Effects team blog
Wallace Karraker
on May 24, 2013 at 12:00:58 am
If you're on a Mac you can re-enable AVI exports from QuickTime 7 on OSX Lion or later...
Missing compression codecs
The gist of the message is this...
In order to enable one of the “legacy video codecs” open /Applications/Utilities/Terminal, copy/paste the appropriate line (or all of them) into a terminal window, and hit return. The effect is instantaneous.
qtdefaults write LegacyVideoCodecs ApplePlanarRGB enabled
qtdefaults write LegacyVideoCodecs SorensonVideo enabled
qtdefaults write LegacyVideoCodecs SorensonVideo3 enabled
qtdefaults write LegacyVideoCodecs AppleBMP enabled
qtdefaults write LegacyVideoCodecs AppleCinepak enabled
qtdefaults write LegacyVideoCodecs AppleH261 enabled
qtdefaults write LegacyVideoCodecs AppleH263 enabled
qtdefaults write LegacyVideoCodecs AppleMotionJPEGA enabled
qtdefaults write LegacyVideoCodecs AppleMotionJPEGB enabled
qtdefaults write LegacyVideoCodecs ApplePNG enabled
qtdefaults write LegacyVideoCodecs AppleNone enabled
qtdefaults write LegacyVideoCodecs AppleVideo enabled
qtdefaults write LegacyVideoCodecs AppleGraphics enabled
qtdefaults write LegacyVideoCodecs AppleTGA enabled
qtdefaults write LegacyVideoCodecs AppleTIFF enabled
qtdefaults write LegacyVideoCodecs AppleComponentVideo enabled
qtdefaults write LegacyVideoCodecs AppleJPEG2000 enabled
qtdefaults write LegacyVideoCodecs ApplePixlet enabled
If you also want to enable all of the “legacy audio codecs” you can copy this line to your terminal:
qtdefaults write LegacyAudioCodecsEnabled yes
Mandla Bolekaja
on May 24, 2013 at 8:46:04 am
Thanks Wallace, this is very helpful.
MB
2.8 Quad-Core, 24 GB Ram, CS6, Mountain Lion
