problem image sequence import in adobe media encoder
COW Forums : Adobe Media Encoder
Yasser Amin
on Sep 18, 2012 at 12:48:51 pm
Hi
have a problem with adobe media encoder CS6, in media encoder preferences I change the Display Format to 25 frame timecode, I import a serial of TGA (170 frame) to media encoder as a TGA image file Sequence, this serial generated from 3D Max and ToonBoom applications, the specification of TGA serial 1080 50i "1920X1080 - upper filed - 25 fps", when I import the sequence, media encoder recognize the sequence as 1920X1080 - progressive - 29.97 fps, in interpret Footage options window I change the settings of the sequence to upper filed - 25 fps, and I export it to quicktime mov 1920X1080 - upper filed - 25 fps uncompressed
the problem:
the duration of mov file is 06:20 and that is correct for 170 frame as 25 fps but the mov file not contain all tga serial image, the image freeze at time code 05:16 (frame number 142) and duplicate the frame 142 to the rest of movie file
if I don't change the frame rate in interpret Footage options window for the tga sequence which media encoder recognize it as 29.97 fps, the mov file contain all TGA frames but with duration of 05:16 which not 25 fps
in adobe media encoder CS5.5 I don't get this problem at all
1- how to solve this problem ??
2- how to force adobe media encoder CS6 to recognize the imported image sequence as 25 fps frame rate ??
thanks
Yasser Amin
Re: problem image sequence import in adobe media encoder
on Sep 18, 2012 at 2:47:55 pm
sorry, don't post system
Windows 7 Ultimate SP1, Adobe Creative Suite Master Collection CS6
