Timecode off 3:18
COW Forums : Adobe Media Encoder
Jeff Griswold
Timecode off 3:18
on Aug 6, 2019 at 2:09:32 pm
Hey all,
We're on PC's using the latest updates. PPro 2019 13.1.4, AME 13.1.3. My timelines are set up DNxHD 1080i 29.97 drop frame. I'm exporting 1080i, 29.97 drop (.mxf files)
When I am exporting a file using AME, AME is changing the start timecode by 3:18. My slates on the exported file should start at 59:45:00 just like I have my timeline setup. However, the TC is showing on the exported file 59:41:12. Everything else is the same. No media has moved or changed timing.
When I export straight from PPro I get the correct result with TC showing 59:45:00.
Again, I have made sure that I'm setup with drop-frame and NOT non-drop.
Any ideas? (I think we found an answer...)
We changed the TC in the Display format in the PPro sequence settings from drop to non-drop. Clicked ok. Then went back and changed the display format back to drop, clicked ok. Upon export the TC showed correctly, 59:45:00. One of those things I guess. Back to editing.
